09-05-2023
02:44 PM
03:50 PM
I am interested in a unique look of rounded images on a full frame sensor by using APC lenses. I want to be able to turn off crop mode when I mount an APC lens on a full frame camera. Please update the firmware to allow this.
09-05-2023 03:09 PM
Would be helpful to share what body/lens you are referring to.
09-05-2023 03:36 PM
Canon EOS-R R body and any RF-S lense
09-05-2023 03:39 PM
09-05-2023 03:42 PM
I want to change it to "FULL"
09-05-2023 06:47 PM
Not sure this is possible, but you can try. If you can't select it from the menu its likely not possible. The camera will likely detect the crop lens and switch for you. The camera may not allow Full setting with an APS-C lens.
~R5 C (1.0.7.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve Studio ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8 ~CarePaks Are Worth It
09-05-2023 07:46 PM
That is exactly what happens. I tested it at B&H today. I'm requesting that this be changed in firmware to allow the choice. I don't believe it will ever happen for technical reasons and more so for marketing reasons. They don't want cheaper RF-S lenses used on full frame cameras. But I'm hoping they prove me wrong!
09-05-2023 10:04 PM
But you can use RF-S lenses on full frame cameras, so not following your logic.
09-05-2023 10:09 PM
As I understand it, the OP does not want the FF camera to automatically reduce the recording area to that of an APS-C sensor when a RF-S lens is connected - as it does now. This is done to make the camera produce a non-vignetted image, but the request is to allow that feature to be bypassed for an artistic effect.
09-06-2023 08:37 AM
Ah, gotcha. I think it would be a long shot though for Canon to update firmware to allow that. Do agree with others in doing this work in post. The resultant images wouldn't of course have the same resolution, but unless very large prints are needed, that shouldn't be an issue.
Actually, if very large prints would be needed (and if the subject is stationary), a single-row or multi-row panorama could be created and then in post, add the vignetting.
