05-17-2023
10:29 AM
10:31 AM
Hi everyone...I recently bought a Canon EOS R to use for astrophotography...I have an R6 I use as well... For some reason the EOS R shutter speed starts at 1/125 sec and goes to 1/8000 sec...M mode. That's it - no other options. If I want 5 sec, 1 sec, etc., I have to put it in bulb mode. I've spent hours searching fort the solution, but can't find it. Help please!!!
05-17-2023 12:31 PM
Yes! I figured it out just now...I went to shutter speed range, which I had no idea existed, and had to set the lowest speed at 30 sec... That fixed the issue. Thank you for your reply - itt made me go re-look at my settings...
05-17-2023 10:51 AM
Are you using the mechanical shutter? i.e., silent shooting is off?
05-17-2023 12:31 PM
01-27-2024 12:07 AM
Can you tell me how you got there? I've got the same problem on an R7, but I can't figure out how you got to "shutter speed range"
01-27-2024 12:16 AM - edited 01-27-2024 12:19 AM
Go to ISO settings in the menu, if necessary check it out in the Advanced User guide and look at P175 If you have ISO speeds set to automatic, you can configure the minimum and maximum shutter speeds for engaging auto ISO. That document is available here: cam.start.canon/en/C005/manual/c005.pdf
01-28-2024 07:09 AM
Go to C.Fn menu page 2 - there you will find the option Set shutter speed range
06-07-2024 02:31 PM
Just to add another potential cause here, I just had the same problem and it was that I had accidentally set my video mode to 120 fps.
