05-26-2021
01:22 PM
08:32 AM
Hi
After being on the shelf for a couple of months my canon eos m6 is giving E32.
it says:
a camera error was detected
will shut down automatically
restart camera
E32
I tried with 2 different lenses and without. as I see this is an lens error.
Is there something i can do.
Thanks
05-27-2021 10:54 AM
What lenses are you using? Are you using EF-M mount lenses?
If you are using an EF adapter, is it made by Canon?
05-29-2021 04:28 AM
hi
Im useing the 15-45 kit lens and an 50mm prime withe an ef-eos m mount
They worked fine for a long time.
Thanks for your response
05-29-2021 11:03 AM
@Berido wrote:hi
If you remove the memory card, and the camera still malfunctions with the EF-M 15-45mm kit lens, then the camera is most likely at fault. Make sure your battery is fully charged, too. An old battery could be the cause, too, but my gut says not.
06-03-2021 03:45 AM
06-04-2021 12:01 PM
Definetely not a lens issue, you will need to bring camera at a service point; it could be a "simple" issue with the orientation sensor. according to what I found online for other canon camera models (sorry just Italian language at the link here at bottom)
https://erkinson.altervista.org/canon-ixus-errore-e32-spiegazione-soluzione/#:~:text=Cosa%20signific...
I hope this helps
