07-24-2022 09:02 AM - last edited on 07-26-2022 08:24 AM by Danny
Camera seems to do the functions of the self-timer, but when I check for photos, they are nowhere to found. I checked both folders for I only have 2. I can take photos in single mode and the photos are in the folder. I do have the power on an after market power adaptor instead of just battery power. I don't know why that would affect the self timer operation. Like I said, it goes through the regular functions after pressing shoot, but no photos appear. Can someone help?
07-24-2022 10:58 AM - edited 07-24-2022 10:59 AM
I agree. Using the shutter self timer should not make a difference. Using a power adapter should not make a difference. But, let’s try to use the self-timer using the battery.
Put the camera in M shooting mode, and reset it back to factory defaults before try the tests using the battery, instead of the power adapter.
Where are your images being stored? On the memory card, or in a computer? After you take a photo can you playback the images in the camera, both with or without the self timer?
07-24-2022 12:46 PM
When I take a single photo I can see the images and they are being stored on a memory card. Using the self timer, it's like it didn't even take the photo. I look and no photos are taken anywhere. I will try it with the regular battery and report back.
07-24-2022 02:56 PM - edited 07-24-2022 02:57 PM
Okay. I assume that you are talking about the 2/10 second shutter delay timer. Right?
07-24-2022 07:21 PM
So I put the regular battery in and the self-timer did what it's supposed to do. I don't know why it works, but it did. The 10 second shutter works. Thanks everyone.
07-24-2022 10:59 AM
First try it without using the off brand power adapter.
07-25-2022 10:34 AM
" I don't know why it works, but it did."
The reason is simple. If Canon did not make a power adapter and you have to buy an off brand unit it generally means the camera is not designed to use one. No matter what the off brand add on does it is best to stick with Canon brand equipment on Canon cameras.
