EOS R6 Mark II and motorsports panning photos
CanonRocks777
I have always been told to turn off Image stabilization while panning motorsports events. Now I have a new Canon EOS R6 Mark II. Should I turn off the internal image stabilization for panning action photos. Please note my lenses either do not have IS or I turn IS off on the lens while shooting.
Thanks in advance!
6 REPLIES 6
p4pictures
If a lens has IS, then the lens IS switch controls when lens AND camera IS operates. Lens IS switch off, no lens IS and no camera IBIS.
If you have lenses that have mode 2 IS setting on them, that is designed for panning. It detects the direction you are intentionally moving the lens when panning and only stabilises other directions. For my lenses when doing panning I always use mode 2 IS and leave it on.
Here's an example with mode 2 selected, IS on the lens switched on, so body IS will be active.
1/30, f/14, ISO 100 EF 70-200mm f/2.8L IS II USM1/30, f/14, ISO 100 EF 70-200mm f/2.8L IS II USM
Brian
Nice shot!
Good explanation and nice example photo.
I usually use mode 3 IS by the switch on the lens when panning a bird in flight, but I have an older lens. For a lens with no stabilization or with no IS switch on the lens, https://cam.start.canon/en/C012/manual/html/UG-04_Shooting-1_0390.html , "Still photo IS" "Only for shot". If the lens has no electronics, the focal length should also be set in the camera menu.
My lense of choice has no IS. I am panning high speed motorcycle  and car motorsports. Do I turn on in body IS or leave it off on my EOS R6 Mark II?
Thanks!
I suggest trying in camera menus  https://cam.start.canon/en/C012/manual/html/UG-04_Shooting-1_0390.html , "Still photo IS" "Only for shot" for panning. My expectation is that this will be best for autofocus vehicle detection.  If manual focus, then I do not know.
ebiggs1
Well I don't have the R6 Mk II but I almost never turn IS off for anything. I do use Mode 2 as suggested above sometimes. Keep in mind as SS increase IS becomes less effective to a point as to not making any difference at all.
IS comes into its own at slow and very slow SS. The Mini was shot a 1/30 SS so I would have used mode 2 with IS on.
EOS 1DX and many lenses.
