07-24-2022 11:57 AM
Hi
I have started noticing clear green banding about 10 percent of the image at the bottom of some of my images when I shoot at higher ISO's Latest ISO's were 800 and 2000. Any Idea how to fix it or would it be a camera issue? The photo was lightened up quite a bit to be able to see it in the link.
Thanks
https://www.flickr.com/photos/128404013@N08/52238298749/in/datetaken-public/
07-24-2022 12:06 PM
I looked at the image of the bridge and did not see banding. I guess there was too much green grass in that part of the image.
07-24-2022 12:12 PM
My firmware is 1.0.4
I see there is a upgrade to 1.3.3
It seems most of the time when I upgrade things I end up with more issues than I had before the upgrade. Willing to try it if it might help.
07-24-2022 12:30 PM - edited 07-24-2022 02:55 PM
You an try the banding feature in AnotherRawTherapee.
Solved this sample https://www.reddit.com/r/canon/comments/6qmf7e/green_band_fixedpattern_noise_in_photos_with/
07-24-2022 12:31 PM
07-24-2022 02:09 PM
Something looks amiss in the first three images. First I would be sure to get all the images you want off the card and then format the card. If that doesn’t resolve the issue you may need to have the camera serviced.
07-24-2022 03:16 PM
That first looks like a sensor issue, to me. But, the band in the second image looks completely different from the first image. If you are not using filters, then I would send the camera in for service. But, before you do, try different memory cards that have been formatted in the camera.
07-25-2022 11:51 AM
I set the long exposure noise reduction in the settings where it was not set before and the green bar on the bottom is gone but there is some light green and yellow horizontal banding through out a really dark shot brightened in photoshop shooting at 3200 ISO. Thinking that just might be from over exposing a really dark shot. I will experiment more with that setting on and see what happens. I did talk to Canon and they said send it in and they would look it over. They did say my camera was probably a grey one not made for the US which bummed me a bit. The serial number did not match the camera. I bought it used back in 2018.
