01-24-2020 03:25 PM
Hey just got this brand new 90d shot with it a couple of times and it's been great and then I picked it up today and it was making this loud ticking/thumping sound when you playback the video. Does anyone know what this is???
01-24-2020 03:41 PM
What lens do you have?
01-24-2020 03:48 PM
@kvbarkley wrote:What lens do you have?
Are you using a tripod? If so, turn off IS in the lens? You can turn off AF Tracking, too, because your subject is pretty static, and not moving around much.
Personally, that sounds like some sort of electronic interference on the microphone. Are you using an external mic? If so, try using just the camera's internal mic to see if the noise goes away.
01-24-2020 05:24 PM
01-24-2020 05:21 PM
01-24-2020 04:33 PM
Going along with Waddizle, is your cellphone next to your camera? I have heard this sort of thing when cellphones get close to speakerphones.
01-24-2020 07:56 PM
lisnlive,
I see from a post below that you disabled the IS whilst on a tripod and the noise went away. What you were hearing was the IS mechanism attempting to correct for shake but being on a tripod, there was none. That is the reason we recommend always disabling the IS when shooting on a tripod, otherwise you risk damaging the IS mechanism in the lens.
01-25-2020 09:21 AM
@Tim wrote:lisnlive,
Actually, the manual for the lens only states that to conserve battery power IS should be turned off when on a tripod.
