12-05-2024
08:15 AM
12:12 PM
SamanthaW
Hi, thanks for your time. I have about zero technical knowledge so kindly excuse me if I use improper terminology. I use a Canon Eos 90D and a Sigma 150-600MM lens. When recording video the camera will wobble. Not shake, it wobbles back and forth even when I have it sitting on a beanbag and it is otherwise completely stationary. The firmware is updated. Image quality is as expected, focus works as normal but it wobbles on its own. Any ideas on a cause / fix? Thanks so much.
12-05-2024 08:42 AM - edited 12-05-2024 08:43 AM
Have you tested it with the OS (Optical Stabilizer) function turned off? I would test that first, both on/off to see if there is any difference. Process of elimination.
R3 ~ R5 ~ R6 Mk II ~ R50
Lenses: RF Trinity and others
Adobe and Topaz Suite for post processing
Personal Gallery
Personal Gallery
12-05-2024 08:55 AM
You hit it on the nail Marc. Older Sigma lenses play “IS tug of war” with the AF system. On the EOS R series it plays with IBIS if the camera has it.
12-13-2024 02:03 PM
Thank you, just got the chance to try it in the field and so far so good!
~onewildlifer
