05-29-2024 04:55 PM - edited 05-29-2024 05:05 PM
I have a 80D and it won’t save photos. When I take a photo the spinning loading symbol comes up and then corrupts the memory card. I have tried multiple different cards in different sizes.
05-29-2024 05:00 PM
Where does it say "loading", generally the only notice you get is the little red light.
I assume you are using full size cards, not micros with adapters.
05-29-2024 05:04 PM
Yes full size cards that I have used since the camera was new. I was wrong it does not say loading. It has the spinning wheel on the screen and then says SD card is corrupted.
05-29-2024 07:01 PM
Have you tried to do a low level format in the camera?
05-31-2024 01:41 PM
I have not as I have not figured out how.
05-31-2024 04:31 PM
From the manual. This is the wrench menu. I always low level format.
06-05-2024 05:56 PM
Thank you for your help but everything I have said has been wrong (my wife isn’t very good at explaining things). The camera takes and saves photos but when the memory card is put into a computer all the images are corrupted. Have tried multiple different cards and it always happens.
06-05-2024 06:00 PM
Are these full size cards? Or micro with adapter?
Did you try the low-level format?
Do they play back fine on the camera? If so, the images on the card aren't corrupted.
Have you tried using the USB cable?
