EOS 80D wi-fi connection
Wmpatton3
I have an EOS 80D. When I try to connect wi-fi to my iPhone im asked for a password. Haven’t a clue what it might be. How can I recover it?
2 ACCEPTED SOLUTIONS
Anonymous
Not applicable
Delete the Wi-Fi setup in the camera and in the phone for your camera and restart the pairing.
@Wmpatton3 wrote:
The only delete I see is delete all camera settings. That might get it.  But to answer your question, no there isn’t a delete for rays iphone
So, you don't see this option in your Wireless communication settings?
Newton
EOS R5, R6, R6II. RF 15-35 f/2.8L, 50mm f/1.2L, 85mm f/1.2L, 100mm f/2.8L Macro, 100-400mm, 100-500mm L, 1.4X.
12 REPLIES 12
Anonymous
Not applicable
I believe that it is asking for your Wi-Fi router's password.
I tried that and it didn’t work. Went into the camera and found the encryption code which should be the password but that doesn’t work either
Anonymous
Not applicable
How do I delete the wi-fi settings on the camera. In going thru the menu it shows connecting to Rays IPhone. That’s not me and may be at the root of my problem
Worked like a top. Thank you
Anonymous
Not applicable
Where you see Rays iPhone, isn't there a delete option? Also you could add a new connection for your phone. Here is a link to the Wireless manual for your camera:
https://gdlp01.c-wss.com/gds/9/0300022459/01/eos80d-wf-im-en.pdf
Anonymous
Not applicable
Try just adding a new connection. Did you download the wireless manual? There's a lot of good info in there.
The camera produces a wi-fi signal that me iPhone finds. I can’t connect the 2 due to not having the password to connect
Avatar
Enter for a chance to win
