EOS 80D Focus
AliReza1422
Hi
I have a Canon camera (80d)
I charged the camera battery
After charging and installing the battery to the camera
The camera turns on but does not focus ( manual and automatic) and shows blur everywhere.
What is the problem?
19 REPLIES 19
kvbarkley
Can you hear it trying to focus? Could the diopter be misadjusted?
Tronhard
VIP
VIP
One way to figure out if the dioptre adjustment needs alteration is to look at the information line at the bottom of the viewfinder. If the numbers are blurry, the dioptre needs adjustment.  Use the small wheel to the right of the viewfinder to alter it.  When the numbers are sharp, when you focus, the image should be sharp.
If that is not the issue, we need to know what lens you are using and if it is switched to AF mode.
cheers, TREVOR
jrhoffman75
@AliReza1422 wrote:
Hi
Does the same thing happen in Live View mode on the rear LCD?
Which lens? Verify that lens is switched to AF.
AliReza1422
My lens is 18-135
And i switched the lens to AF
But the camera ahows blur everywhere
1. When you press the shutter button do you hear the lens try and focus?
2. Have you tried to use Live View?
Did you check the dioptre to make sure the display is in focus?
cheers, TREVOR
Yes i use live view but ...
I can't hear any sound
Yes bro
OK. If you switch lens to MF and hold the shutter button down halfway (to activate camera) and turn the focusing ring does the lens focus? When you said in Live View no sound, is the image on the LCD fuzzy, as in the viewfinder?
Do you have another lens to try?
