05-18-2023
04:32 PM
09:36 AM
Whatever they are show up on several bodies & lenses. They happen frequently at one of the drag strips I shoot at. Often times they are in different parts of the image. I have seen them at another track I shoot at but only a couple of times in the 40k images or so I have shot there. All lenses and sensors are clean. 7DM26952.jpg
05-18-2023 04:39 PM - edited 05-18-2023 04:39 PM
So that the Community can help you better, we will need to know which model camera and lens you have? Any other details you'd like to give will only help the Community better understand your issue.
05-18-2023 04:48 PM - edited 05-18-2023 04:48 PM
It looks like there is dust on the image sensor.
05-18-2023 04:58 PM
This particular image was taken with a 7D Mark II with a first gen 400 L 2.8. But they have appeared on all my bodies no matter which lens I use.
05-18-2023 04:58 PM
Will check it.
05-18-2023 05:55 PM
@inkjunkie wrote:This particular image was taken with a 7D Mark II with a first gen 400 L 2.8. But they have appeared on all my bodies no matter which lens I use.
I find that hard to believe.
It is most likely spots on your camera's sensor, in which case they will appear in all images made with that particular camera, but they may be hard to see in some images and will not appear in images made with other cameras.
There is a more remote possibility that it's something on the rear element of the lens, in which case they will appear in all images made with that lens, regardless of the camera it's on. Usually things inside or on the front element of a lens will not show up in images. It takes something really large and very obvious. That's especially true with more powerful telephoto lenses. However, in some cases "stuff" inside a lens can cause flare that shows up in images.
What I notice in the image you posted is that those appear to be residue left behind by dried droplets. Could rain drops have gotten onto the sensor or the rear element of the lens? It's also possible for droplets of oil to get onto a sensor, perhaps lubrication thrown off from the camera's shutter.
Alan Myers
San Jose, Calif., USA
GEAR: 5DII, 7DII (x2), 7D(x2), EOS M5, some other cameras, various lenses & accessories
FLICKR
05-18-2023 07:46 PM - edited 05-18-2023 07:53 PM
Just shot this at F16 on a white sheet of paper....looked at in in Camera Raw, there does appear to be some spots on the sensor that are very faint...will take the lens off later and take a look7DM27225.JPG
05-18-2023 07:57 PM
I highly doubt multiple cameras are showing dust on the image sensor. Unless all of them have dust on the image sensors.
05-18-2023 09:21 PM
A bright flashlight held at different angles should help you determine the source. Through the lens, on sensor, etc.
05-19-2023 10:07 AM
@inkjunkie wrote:Whatever they are show up on several bodies & lenses. They happen frequently at one of the drag strips I shoot at. Often times they are in different parts of the image. I have seen them at another track I shoot at but only a couple of times in the 40k images or so I have shot there. All lenses and sensors are clean.
What am I supposed to be looking at? This looks like a 1D series body on a tripod with what appears to be a remote trigger. This image is also out of focus.
