05-18-2023 11:15 PM
Hello,
Have a couple of problems with my 90D I'm hoping someone might be able to help - many thanks:
Any help would be greatly appreciated.
Jose
05-19-2023 04:44 PM
Once again Hubert, many thanks.
Hope this info helps someone else in the future! The VF diopter notwithstanding! 😞
Many thanks again @Huberthardin!
Jose
05-19-2023 05:03 AM
Hello,
High-Speed Shooting in Live View Mode:
It seems like there might be a setting that is causing the high burst setting to be grayed out in Live View mode. Here are a few things you can try:
Make sure you are in a shooting mode that supports high-speed continuous shooting. Some shooting modes, such as Aperture Priority or Manual mode, may limit the burst shooting capabilities. Try switching to a mode like Program (P) or Sports mode.
Check the camera's drive mode settings. Press the Drive mode button (located near the top-right side of the camera) and rotate the main dial to select the high-speed continuous shooting mode. Make sure it is not set to single shot or any other mode that disables burst shooting.
Confirm that the autofocus (AF) area selection mode is set correctly for Live View shooting. Press the AF point selection button (located near the top-right side of the camera, below the Drive mode button) and use the multi-controller or the touchscreen to select a suitable AF area mode for your shooting needs. For burst shooting, you might want to select the Zone AF or Automatic AF point selection mode.
Reset the camera settings to their factory defaults. This can help eliminate any unintended settings that might be causing the issue. Look for the "Clear all camera settings" option in the menu or refer to your camera's manual for instructions on performing a factory reset.
If none of these steps resolve the issue, it's recommended to consult the camera's manual or reach out to Canon customer support for further assistance.
Blurry View via the Viewfinder:
If your viewfinder images are consistently blurry while using back button focusing, here are a few suggestions to address the issue:
Ensure that the viewfinder diopter is properly adjusted. The viewfinder diopter adjustment dial, usually located near the viewfinder, allows you to focus the viewfinder to match your eyesight. Adjust it until the viewfinder information appears sharp and clear to you.
Clean the viewfinder and the eyepiece. Sometimes, smudges or dirt on the viewfinder or eyepiece can affect the clarity of the view. Use a soft, lint-free cloth to clean them gently.
Check your lens for any issues. Even though the lens performs fine in Live View mode, it's worth verifying if there are any problems specific to the viewfinder focusing. Ensure the lens is properly mounted, clean the lens contacts, and consider trying a different lens to see if the issue persists.
05-19-2023 08:39 AM
Many thanks Huberthardin for answering both of my concerns so thoroughly, I appreciate it.
I will try them and report back.
Jose
05-19-2023 04:44 PM
Jose
