01-03-2024 01:33 PM - last edited on 01-03-2024 01:52 PM by Danny
Can someone explain to me, how can I connect external monitor to Canon 7D?
01-03-2024 08:59 PM
I want to use for shooting.
01-03-2024 09:03 PM - edited 01-03-2024 09:03 PM
Just to clarify this:
You want to use an external monitor for shooting video and/or still images. Currently you have had to use just the optical viewfinder in the camera and that's not working for you, so you need to connect this external device so you can look at that instead of either the optical viewfinder, or LCD of the camera.
If that is the case, as long as your Freeworld LCD 7" monitor has an HDMI input, you should be able to apply the settings outlined in P185 of the manual.
01-03-2024 08:58 PM
I have been trying to connect the feelworld 7'' external monitor
01-03-2024 08:59 PM
OK, so what input ports does it have please?
01-03-2024 09:02 PM
with other canon cameras, you can use an external monitor as your screen. However with 7D, I connected the same monitor and it does not display the image.
01-03-2024 09:11 PM
What cameras and what method are you using that works for you but not here?
I looked up the Freeworld 7" monitor range and according to their specs, they all accept 1920x1080 as an input resolution which is the output for the 7D for video. When you say you can use "AN external monitor" have you used THIS monitor with other Canon cameras or are you going by what you have read? As long as the HDMI is up to spec (as in the manual) it should work, if the HDMI is not the right specific type, you will have issues.
01-04-2024 05:07 AM
The feelworld has a mini HDMI to a regular hdmi. This I what I’ve been using with other canon cameras. I’ll change the cable and see. Thank you
01-04-2024 12:05 PM
Well, we don't know if that is the issue until it works, but I sincerely hope so. Good luck with that and if it turns out to not fix the issue come back to us!
01-03-2024 10:17 PM
moraisluc221,
I guess I have to thank you. Before you asked your question, I didn't know anything about external monitors or field monitors. I've learned a lot in researching your question.
Theoretically, it should work.
Have you asked the Feelgood people if your 7D is compatible?
The only thing I can think of at this point, is are you using the HDMI cable recommended in your 7D manual?
Steve Thomas
