09-06-2023
10:26 AM
10:31 AM
I just updated my MAC24 to Ventura 13.5.1 and updated the Canon EOS Utility 3. I have a 750D [Serial number removed per forum guidelines]. I have a problem connecting via USB. WIFI is disabled on the camera (I am unsure how to connect wifi!). I also tried Image Capture but the camera is not shown.... The USB cable is the original with a USB-A connector to the MAC. I bought an adapter for USB-C.
Any suggestions or advise please!!
Thanks
Chris
09-06-2023 10:36 AM
It’s a known problem. Many posts on the site. No known workaround.
09-06-2023 11:16 AM
How much do you trust the Internet? I recall reading about how Ventura disables the USB ports once it has been installed.
Apple seems to have a brief knowledge base article about the issue, which I do not think is very helpful, not at all. It basically tells you to contact Apple Support directly if you are having these problems described at the link..
https://support.apple.com/en-us/HT204377
09-06-2023 11:22 AM
Doesn’t work. As I reported in a previous post, no trouble connecting to Image Capture, Lightroom tethering or Kuuvik Capture tethering. It is an EOSU problem with macOS Ventura.
