12-01-2013 10:34 AM - last edited on 05-07-2024 08:49 AM by Danny
I'm thinking about upgrading my Canon Rebel t1I to the Canon 60D. What would be the advantanges of the 60D. I've been looking at the specs and comparing the two cameras but nothing is jumping out at me. I've only been using my DSLR for a year, but I've been taking classes and I think I'm ready for the upgrade, I just want it to make sense.
12-01-2013 11:13 AM
12-01-2013 11:13 AM
12-02-2013 09:11 AM - edited 02-18-2017 08:44 AM
Tim has nailed this to the wall. This choice is more a function over specs. If the 60D fits your requirements better go for it.
12-09-2013 05:32 AM
02-18-2017 12:58 AM
I have canon EOS 60D camera but am facing strainge problem since 1 year. The issue is with focussing. The focus takes tto long or sometimes it does find any focus point. The lense I am using is 18-55mm Canon lense. I cleaned the ;ense but there is no use.Still I am facing the problem with focus. Please suggeste solution.
02-18-2017 08:35 AM
The lens would have to be incredibly dirty to affect the focusing, so forget that idea.
Firstly make sure you have enough light, you will find that the 18-55 can struggle to achieve focus in poor light especially indoors.
Perform a "master reset to default to factory settings" in the menu, then remove the battery for 15 minutes and refit.
See if the focus problem is the same on both live view and through the viewfinder because they use different focus systems in the camera, do the reset first in case your AF system has been set up differently.
Try another lens, if you do not have one then go to a camera dealer and try another similar lens even if you have to pretend you are intending to buy.
09-26-2017 09:49 PM
hi i havent used camera since november , now power goes on and off whilst turning main dail on top of camera, not batteries etc Can anyone advise. As in country and no where near a canon repairer or anything
thankyou
kylie
05-06-2024 06:09 PM
Just bought myself a used Canon 60d. Yes I am an enthusiast for photography. I'm looking forward to using it after I receive the charger and batteries ordered for this. The thing is when I purchased the t7 it was filled with dust all over the sensor and mirror. Over time the dust started appearing on the photos and I have done the best in cleaning this camera; but mind you the t7 takes wonderful pictures if only the magnified dust particles didn't show on screen or print. I just happen to enjoy photography and this 60d is what say 14yrs old? Meh! I've just got to see how it works Guys.
Wish me well. Take a look at these night shots taken with the t7 and EF 75-300Mm Canon lens.
05-07-2024 11:29 AM
Good luck with your new baby but you posted on a nearly 10 year old thread. You can start your own new thread and u/l photos.
