02-04-2024
03:33 PM
09:04 AM
I have found many posts about this issue but haven't been able to find a solution that works for me. I have a 60D, has worked flawlessly for many years, but recently started having this issue.
Here is what I have tried:
Anyone got any advice here? Canon has unfortunately ended service for this model, so no help there. Hoping I don't have a brick on my hands.
TIA.
02-04-2024 03:36 PM
Try resetting the camera back to factory defaults. Perhaps you've enabled some feature that is leading to the higher write times.
02-04-2024 04:41 PM
Ricky,
Thanks for the suggestion. I should have noted that I did also already try to reset the settings in the camera using the functions available in the on-camera menu. Just for good measure, if just tried that again but unfortunately it did not have any effect. Problem still present.
I did just find a mention of a small button backup battery and a teardown and replacement video on YouTube. https://www.youtube.com/watch?v=vVZLdSoz1X4 Looks like a promising path that I may attempt next.
02-04-2024 05:44 PM
The internal battery only powers the clock circuit. With a dead internal battery the camera would, barring some other problem, still turn on, only resulting in the clock having to be reset every time you turn on the camera.
That video is kind of vague about what he is doing, and no mention of what KIND of batteries he is trying. If it is not a rechargeable battery, he'd have to replace it when it wears out, just like a battery in a watch
02-04-2024 07:25 PM
“ Low Level Formatting all cards. Tried this, multiple times. No joy, “
What does that mean? I cannot be certain. Did the low level format fail? Or did low level format not correct your issue?
A quick and dirty way to determine if you have a changed setting somewhere is to try switching the camera into fully automatic mode, the Green[A+] setting on the shooting mode dial.
Make sure that you only use full size SD cards. Purchase them from a reputable dealer, preferably a Factory Authorized Canon dealer, not Amazon. There are a whole lot of counterfeit camera accessories being sold on Amazon. Some vendors do not even realize they have counterfeit stuff, but many of them do.
02-04-2024 07:32 PM
What I meant by that is that formatting the cards did not fix the issue. The Low Level Format completes successfully, but the issue persists afterward.
All cards are reputable brand, full size cards. The original 64GB Cards were the ones I have been using for at least the last 5+ years with no prior issues. The new card I bought to test the "bad card/s" theory is also an authentic, full size SanDisk Extreme Pro card. Three cards, all exhibiting the same issue seemed like enough evidence that the cards are not the issue, but just for good measure, I threw a Kingston card in just to change manufacturers. Same issue with the Kingston card as well. At this point I think it is highly unlikely that the SD card is the issue as the problem persists across 4 different cards.
02-04-2024 07:35 PM
Yeah, in that video he is trying to solve for a different issue than what I am having. My camera powers on fine, I'm just looking for a way to completely power it down. My working theory right now (weak as it may be) is that something is corrupted in the internal cache memory and that the only way to COMPLETLY factory rest it is to remove that battery.
Weak theory I know, but it's all I got right now. Not in a hurry to disassemble it though, still hoping someone here has a better idea.
02-05-2024 02:03 PM
Short of returning the camera to service, I'd have look and see if there is anything in the camera SD slot that might be blocking the contacts. Otherwise it could be possible that the camera SD slot has "worn out" and only makes inconsistent connections
02-05-2024 05:09 PM
“ A quick and dirty way to determine if you have a changed setting somewhere is to try switching the camera into fully automatic mode, the Green[A+] setting on the shooting mode dial. “
Have you tried this, yet? If not, I suggest that you do. It only fakes a few seconds.
Invoking the menu selection to “restore factory defaults” does NOT fully reset the camera. You would have to go through the menu system and reset at least a half dozen items to fully reset the camera.
02-05-2024 08:07 PM
zavoq,
You mentioned, "the SD card busy light stays on and the exposures remaining display flashes"
and, "Turning the power switch off when it's in this state extinguishes most of the other items on the LCD, but the exposures remaining counter still flashes...".
How many photos are you trying to take at a time? Is it one or two, or is 20 or 30?
This is just a guess on my part, but It could be that you are overloading the buffer.
Steve Thomas
