09-04-2023
06:07 PM
09:43 AM
Im having issues with firing my flash. ive used to a good amount of times before but as of the last time I was shooting the flash stopped firing. As since I can only get it to fire a few times in "ETTL" mode but in Manual the flash is not firing at all. I have made sure to disable silent live view but it still will not fire, in live view or through the viewfinder nothing is working with the trigger OR with the flash mounted on the camera. any ideas?
09-05-2023 08:13 AM
no but I tried the trigger on my canon 5d mark ii and it worked
09-05-2023 08:28 AM
The trigger may be incompatible.
09-05-2023 08:29 AM
I have used it before tho, and it fires a few times if its in ETTL but not in manual
09-05-2023 08:31 AM - edited 09-05-2023 08:31 AM
It may not be communicating with your camera correctly.
09-05-2023 09:28 AM
Do you have a Canon speedlite to try on your camera?
09-05-2023
08:38 PM
08:46 PM
Tiffany
My v1-c is does not fire with the flash in manual mode on my canon 5d mark iv, but on ettl mode it will fire perfectly fine. I also tried putting it on my 5d mark ii and there it works fine in manual, anybody know the issue?
09-06-2023 07:31 AM
I suggest that you contact Godox about your issue.
