EOS 5D Mark IV not triggering Godox Xpro & Godox V1-C
Mistermixson
Im having issues with firing my flash. ive used to a good amount of times before but as of the last time I was shooting the flash stopped firing. As since I can only get it to fire a few times in "ETTL" mode but in Manual the flash is not firing at all. I have made sure to disable silent live view but it still will not fire, in live view or through the viewfinder nothing is working with the trigger OR with the flash mounted on the camera. any ideas?
16 REPLIES 16
no but I tried the trigger on my canon 5d mark ii and it worked
The trigger may be incompatible.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
I have used it before tho, and it fires a few times if its in ETTL but not in manual
It may not be communicating with your camera correctly.
-Demetrius
Anonymous
Not applicable
Do you have a Canon speedlite to try on your camera?
Mistermixson
My v1-c is does not fire with the flash in manual mode on my canon 5d mark iv, but on ettl mode it will fire perfectly fine. I also tried putting it on my 5d mark ii and there it works fine in manual, anybody know the issue?
I suggest that you contact Godox about your issue.
