01-17-2023
08:55 AM
09:30 AM
I have been told that my camera (EOS Rebel Xsi is no longer supported by Canon. EOS Utility software does not exist for MacOS 13.1 (Ventura). However, I want to download photos from EOS Rebel Xsi WITHOUT using canon software (it doesn't exit for my computer) to my computer. Any suggestions? Thanks.
01-17-2023 09:05 AM - edited 01-17-2023 09:05 AM
SanDisk is one brand you could go with. Be sure though to choose a connector that will work with your computer.
e.g. SanDisk has a "SanDisk Extreme Pro SD Card USB Type-C Reader" product (manufacturer part #: SDDR-409-A46) that connects via USB-C. If your Mac doesn't have USB-C, but older USB ports, you could use their "SanDisk UHS-I SD Card Reader" product instead (manufacturer part #: SDDR-C531-ANANN)
01-17-2023 08:57 AM
Does your Mac have a built-in SD card reader? If not, such readers are inexpensive and typically the best method to transfer photos to your computer.
01-17-2023 08:59 AM
Thank you for your reply. I honestly don't think so. I will look into the card reader. Any suggestions?
01-17-2023 09:12 AM
Ricky,
Many thanks. That sounds like a solution!! Have a great day.
Bob
01-24-2023 01:18 PM
Ricky,
I thought I would close the loop. Your suggestion to use a card reader worked perfectly. Thank you for your help.
01-17-2023 09:21 AM
While most folks here will recommend the use of a card reader (as Ricky did), you can also use the Mac software Image Capture.
