Disabling Auto Power Off for Good in the R5?
Redshift48
I have made changes to disable Auto Power Off on my R5 in the Power Saving Menu but if I turn off the camera and then back on, it reverts to the default (?) settings of 30 seconds display and auto power off.  How can I make it permanent?
1 REPLY 1
John_Q
Hello Redshift48,
The changes you made should be maintained after powering the camera off. The default settings for Auto power off and Display off should be 1 min, while Viewfinder off is 3 min. I would suggest resetting the camera to default settings and starting there. You can save the current camera settings to a memory card prior to resetting the camera if you would like to. That option is in the yellow Tools (wrench) menu #5. The camera needs to be in a Creative mode such as P, Av, Tv, or M to access all of the menu items. You can find the reset in the yellow Wrench Menu #5. There is also the Clear customized settings Menu item in orange camera #3 menu. Doing both of these will reset the camera to default settings.
