Connecting sound board (mixer) to Eos R10
Teeder
I’ve just received the EOS R10 and would like to know if others have had any experience connecting a sound board. I’m presuming the mixer would connect via the 3.5 mm input on the camera, meaning I’m reducing the 1/4” or XLR from the mixer to fit the 3.5 mm.  Does anyone have experience with this? Thanks
Right, understood. Will look into this. Thanks Ricky.
9 REPLIES 9
Waddizzle
Have you read the specifications for your camera?  It does not appear to have an input for an external microphone.  It has “Audio Out”, but no audio/mic input.  I believe you will need an external recorder.
Hi Wad. Yes, the camera does have a 3.55 Jack which can be used as an input for external mic or sound board.
Indeed it is a typo as the manual makes clear.
rs-eos
What are you trying to accomplish?  The camera's 3.5mm jack is for input (typically a microphone).  Are you wanting to output signals from the mixer into the camera?  Or are you wanting to feed audio out from the camera to the mixer?  The camera doesn't have any audio output.
Ricky
EOS 5D IV, EF 50mm f/1.2L, EF 135mm f/2L, 600EX-RT (x6), ST-E3-RT
EOS C70, RF 24-70 f/2.8L IS, EF-EOS R 0.71x
Thanks for your quick reply Ricky. Yes, I am looking to live stream music with vocals, so need to have balance control of vocals and instruments. So, output from mixer into camera.
Note that it is a microphone input and you may need to attenuate the output of the mixer.
I'm not sure if that would work as I don't see any settings for audio input regarding line level input (I'm assuming the mixer would output line level signals).
Since there's a difference between line level and mic level regarding current (line being higher and mic being lower), I would not risk hooking up the mixer to the camera's mic input.  Unless you'd know for sure that the mixer can output a signal for mic-level inputs.
Ricky
