03-05-2020 11:01 PM - edited 03-05-2020 11:03 PM
For some reason all of a sudden, when i transfer my files from the SD card to my laptop or my desktop and I play them, the video shows pixilations every couple of seconds. I check to make sure the camera wasnt over heating, I formated my sd card using the camera, and i even updated firmware. Anyone had this problem? This is time sensitive.
there is no pixilation when viewing it from the camera itself.
03-05-2020 11:48 PM
animeprodigy32,
There are a few troubleshooting steps I'd like to help resolve this issue. We'll reset the camera, which should restore it to a default state. These steps should clear out the memory and thereby any errors which may be present.
- Anything attached or installed in the camera — memory cards, the lens, the battery, battery grips should all be removed.
- Once the lens is off let's check it using the steps below.
a) Clean the lens contacts* to restore connection with the body.
b) Try using a different memory card. All memory cards should be properly formatted in your camera prior to use.
*Warning - Do not clean lens contacts on either a Canon lens or the camera body with an eraser! It's easy to rub off the gold plating on these contacts and end up with data communication problems! Our strong recommendation is to use a soft, clean, micro fiber cloth. Please do not use anything abrasive.
c) Try using a different Canon EF series lens. It doesn't have to be the same focal length as the one you were using.
d) If you are using a third party lens, we recommend discontinuing its use. There can sometimes be communication error related issues with third-party lenses. Ensuring that you're using a Canon lens eliminates that as a potential factor in the error.
If the issues seem to persist the next step would be to send the equipment to Canon for service.
You may fill out an online repair request form at the following link to setup your repair using our online service.
www.usa.canon.com/repair
