08-26-2017 06:16 AM
I got a Canon T50 35mm in a garage sale for a few dollars, batteries are in and i'm wondering what is the iso for a color film that i should get for it and the same for black and white.
I have read some part of the user manual but because i'm using EOS camera since a long time i would like to have your recommandations about that.
Thank you
08-26-2017 11:30 PM
Hi Bertrand1,
Thanks for posting.
Regardless of whether you're using color or black & white film, its ISO number (for example ISO 100) represent its sensitivity to light. The higher the number, the less light needed for an exposure. Thus with ISO 400 you can shoot even in dim light.
For typical daylight shots, I'd use a speed, such as 100. In brilliantly lit areas, an ISO speed of 25 may be all you need. If you're shooting at night, an ISO film speed of 1000 or even 1600 may be needed.
08-27-2017 01:14 AM
One of my favorites is Fujifilm Fujicolor 200 Color Negative Film. ISO is 200. Kodak Tri-X Pan 400 is one of my favorite B&W. ISO is 400.
The basic rule of thumb is the Sunny 16 Rule. It says in bright daylight you set the camera like this; If your ISO is 200 at f/16, then your shutter speed will be 1/200 seconds. If your ISO is 400, then your shutter speed will be 1/400 seconds or the closest which would be 1/500 on a T50.
08-27-2017 01:25 AM
Of course the granddaddy and likely the best film ever was Kodachrome. Kodachrome was the first color film that used a subtractive color method to be successfully mass-marketed. No longer made.
A close second is Ektachrome. Ektachrome had the advantage of being able to be processed by almost anyone. Kodachrome requires a complex lab to process. Ektachrome is also much faster than Kodachrome, meaning a higher ISO number.
08-26-2017 11:30 PM
Hi Bertrand1,
Thanks for posting.
08-27-2017 01:14 AM
08-27-2017 01:25 AM
08-27-2017 05:20 AM
Thanks all for the replies.
I take a lot of photography, i have a T2i and a T3i (i know they are not really new) and i have 5 different lenses that i can use with them so i know a little bit about ISO, aperture and other configurations. A photograph in my area told me once to invest in lenses more than in camera and that is what i did 🙂
With old 35mm camera and film i'm a beginner and for me it's to know if the result is going to be the same. I want to use the best film and learn what configuration you use in daylight or in dim light or in the middle of the night. Some film are probably better in certain condition so keep writing your advices and thanks for doing it.
08-27-2017 10:29 AM
In that case you want Ektachrome. It has a huge ISO range possible. You can process it yourself. Last current Ektachrome process is E6 and is used for all major color reversal films. Ektachrome can be easily push-processed to ISO 1600. It is supposed to return this year but I really don't keep up on it. Just what I hear from the grapevine. Check some of the big retail stores to see what they have.
06-23-2020 08:59 PM
I just found my dad's old T50
I was wondering if there should be anything I should know before using the camera and what areas should I clean
06-28-2020 01:42 PM
@Tony2001 wrote:I just found my dad's old T50
My opinion: Treat the camera as an antique. Display it on a shelf in your library or family room. Or offer it to your local photography museum.
If you absolutely must use it, don't even start until you're sure you know the difference between color negative and color positive film, and what that difference means to a user.
And a final thought: Keep in mind that were your dad around today, he would be using a digital camera.
06-23-2020 11:28 PM
06-23-2020 11:29 PM
