Canon R8 Eyecup structure damage
kenken023
I damage the eyecup structure that holds it with the body when I was travelling. The structure with the screw was broken and the eyecup is not firm anymore. Is this possible to be repaired? 😞
Sorry this has happened.  This appears repairable, but its not going to be inexpensive.  This portion of the eyepiece is part of the top assembly.  If you have a Carepak thats a plus.  Next step, register your product in MyCanon, open a support case and you'll get an estimated cost for repair.  The camera will need to be inspected.
MyCanon
4 REPLIES 4
MyCanon
kenken023
Thank you very much for your reply. I will contact Canon support and see how it goes.
Hope it works out.  Here is a better angle.  Following the lines of the body, its not the top, but the back of the body that will need to be replaced.
kenken023
I now understand. Thank you very much!
Friends and Family
