06-03-2022 05:32 PM
06-03-2022 06:10 PM - edited 06-03-2022 09:07 PM
Hi AJ:
Welcome to the forum. Sorry to see you are having issues with the recording process. Does your record to card settings screens look like the following? If not, I would check your firmware version, which should be 1.5.2.
And then...
The playback options would be set to card 1 or 2...
06-03-2022 06:50 PM
What recording mode or format are you using? Some modes may not record to both cards.
06-03-2022 07:12 PM - edited 06-03-2022 07:14 PM
The R6 does not have that last option.
06-03-2022 08:16 PM - edited 06-03-2022 08:33 PM
The photos in my post are directly off my R6 display. This feature was updated on firmware 1.4.0, and my camera is updated to version 1.5.2, which is the current version as of this date.
If you refer to the EOS R6 User guide that is updated to firmware 1.5.0, on P699, you will see the same images as I posted.
06-04-2022 01:54 AM
Hi ajhuemmer,
The main things for recording video to multiple cards on the EOS R6 the main things would be to make sure the recording options are set like in Tronhard's original post and to make sure your firmware is up to date.
Beyond that there aren't any other settings to enable the record to multiple. One thing to check would be to lower the resolution and if you are using something like Canon Log or High Frame rate try turning those off. If one of the cards is not writing the file fast enough it could cause something like this to happen.
