Canon R6 not reaching 12 fps
weekleyba
I am not able to reach 12 fps with my new R6.
I've went through the all the requirements I could find.
Using full battery LP-E6NH, Anti-flicker off, max aperture used (2.8), shutter at 1/1250, mechanical shutter set, WiFi disabled.
I get the green H+ symbol.
Using EF 70-200mm 2.8L IS III USM & EF 24-70mm IS II USM, with Canon control ring adapter.
Used a iPhone with a stopwatch to count pictures.  Right at 6 fps.
What am I missing?
weekleyba
I figured it out.  I thought I was in high speed mode but I was not.  I was only getting the green H and not the green H+.  Switch modes and I get 12 fps in RAW.  Funny how you can overlook the obvious!!
2 REPLIES 2
weekleyba
weekleyba
I did some more testing and found with my EF 70-200mm 2.8L IS III USM lens, I can go less then the 1/1000 shutter speed and neck down my aperature from the max of 2.8 and still achieve 12 fps.  I adjust down both to 1/640 and f4.0  and still got 12 fps.  This is good news!
Friends and Family
