04-25-2026 04:37 AM
Just got R6 Mark II, used an LPE6P battery at 89% and it worked for the first 3 minutes. Turned it off for a bit and then wont turn on again.
04-25-2026 12:43 PM
I'd go back to the seller. Hopefully he purchased from a reliable source.
04-25-2026 09:23 AM
ItsRakky,
Have you made sure that your battery door is firmly shut?
Steve Thomas
04-25-2026 09:29 AM
Very much so, firmly shut. SD slot as well. I've done it multiple times, to check. Battery is also not an issue as I tested with my 80D. The indicator light doesnt flash, when the battery is installed.
04-25-2026 12:10 PM
ItsRakky,
You may have a broken wire. If the camera is still brand new, it should still be under warranty. I'd contact Canon Support.
Steve Thomas
04-25-2026 12:43 PM
04-26-2026 09:34 PM
Yeah unfortunately, it seems that particular R6 Mark II was basically dead on arrival and was replaced by the source. Thanks everyone!
