Canon EOS RP live view flickering
micahpaninga
Hello
Brand new Canon EOS RP was working fine until a few moments ago when the screen started flickering.
This happened at home, and I saw the exact moment it started. Camera was connected to PC and the EOS utility app open.
Any idea what could have cause this?
8 REPLIES 8
deebatman316
Does it do this when not connected to the computer.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
Also does this when not connected to the computer since after the first time. Does this with lens attached or detached.
Reset all settings but no difference.
Can record videos (looks like recording in total darkness and can barely make out light bulbs), but wont take photos when shutter button pressed. Attempted adjusting ISO, no difference.
-Micah
Bodies: EOS RP
Lenses: RF 24-105mm f/4-7.1 IS STM
Greetings Micahpaninga,
For our knowledge, where was this camera purchased from?
Please ensure you are using a Canon OEM Battery.  Also what brand and model is your SD Card?  It should be full size not micro SD or adapted.  Do you have another one you can test with.
~R5 C (1.1.2.1), ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve Studio ~ImageClass MF644Cdw MF656Cdw ~Pixel 10 ~CarePaks Are Worth It
-Micah
Bodies: EOS RP
Probably won't work, but you can try tis.
1. power off camera.
2. remove battery, lens and card.
3. power on camera and cycle shutter button a few times
4. reassemble and see if it is improved.
If not you need to register your product (if you haven't already) and contact Canon for support.
On-line Product Registration for Your Canon Product
Greetings shadowsports
Camera was purchased in Nigeria as brand new, for office use. Trying to get specific store details from procurement department.
Canon OEM battery attached.
Card is Sandisk (32GB), full size. Attempting to get another to test with.
Followed jrhoffman75's step by step instruction above and flickering decreased for a short moment.
Greetings jrhoffman75,
Followed the above steps. Flickering decreased for a short moment but returned to previous worse state after turning off and on.
I wasn't optimistic, but sometimes that process can drain off a retained charge. Sounds like you need to contact Canon for repair.
Roger that. Thank you.
