Canon EOS R6 mark 2 raw files noisy and grainy.
Terry_R6mk2
(fyi-I have open this new discussion as a reference point)
Seems like I am having the same issue with the grainy photos, I shoot in raw, for wildlife (birds) in flight I shoot manual, auto ISO with shutter speed above 1200 for eagles, ducks and 5000 for hummingbirds. The shots look clear and clean when taking them and even after in the camera but when downloaded to my PC, it shows as below, even after processing in lightroom, it still does not look as sharp as should be.
Using Canon EOS R6 mk2 with Sigma 150mm - 600mm contemporary glass.
 Not sure why the raw is so grainy, anyone having the same issue?
"Just focus on what's important and capture the good times, develop from the negatives, and if things don't work out, just take another shot.” – Anonymous.
15 REPLIES 15
daphnemac
I have the same lens and same issue
I lowered my auto ISO in the menu and took more shots, they were much better but Canon need to fix that thing about what we see it clean and sharp in the camera review as to what comes out on the computer which has a measure of blur.
Start a new thread and share some raw files.
TomRamsey
Mentor
Mentor
Your ISO is too high, it may be 'OK' for a subject tight in the frame on a brighter day, but the noise is too much.
A lot of photos may look better on the camera screen than they will on the bigger computer screen.  Zoom in on your review and it may not look so good.  Many photos look good on the camera screen, that's why so many phone photos look great on the phone.
Hey Trevor-I was new to this site and feeling my way around at the time.
No problem - it wasn't a criticism, but intended to reduce confusion - one gets people reading one thread and answering another, and all sorts of other cross-talk confusion.  I know this site takes a bit to get used to!🙂
On the subject of noise:
Inevitably, a RAW file will show more noise and less dynamic range than, say, a JPG file.  That said, with respect, I can only agree with the comments that your ISO values are too high, in order to achieve what seems to me to be an unnecessarily high shutter speed.  For the static image in particular, you could get away with a shutter speed in the area of 1/200 sec, that would give you 3 stops of light that can reduce the ISO from 25,600 to 3,200 which would make all the difference.  In my shots, I don't have the same lens as you, but the settings are relatable.
For example, this shot was taken in extremely dim light, and despite that there is essentially no noise.  Part of this is the other settings that allow a lower ISO, and part is slightly brighter exposure setting to reduce under-exposure and thus noise from that source.  Both shots taken in available light, hand-held.  The originals were RAW and processed in Photoshop using default lens corrections, possibly cropped, and file is resized for posting here as JPG files.
Taieke: R6II, RF200-800@400mm, f/8, 1/50sec, ISO-6400Taieke: R6II, RF200-800@400mm, f/8, 1/50sec, ISO-6400
This second image, also in very dim light also shows little noise, and that is the older original R6.
Kea: R6, RF 200-800@742mm, f/9, 1/100sec, ISO-1600Kea: R6, RF 200-800@742mm, f/9, 1/100sec, ISO-1600
cheers, TREVOR
