01-15-2024 05:43 PM - edited 01-16-2024 02:57 PM
(fyi-I have open this new discussion as a reference point)
Seems like I am having the same issue with the grainy photos, I shoot in raw, for wildlife (birds) in flight I shoot manual, auto ISO with shutter speed above 1200 for eagles, ducks and 5000 for hummingbirds. The shots look clear and clean when taking them and even after in the camera but when downloaded to my PC, it shows as below, even after processing in lightroom, it still does not look as sharp as should be.
Using Canon EOS R6 mk2 with Sigma 150mm - 600mm contemporary glass.
Not sure why the raw is so grainy, anyone having the same issue?
01-15-2024 07:35 PM
ISO 25,600 most likely. Looks good in camera because it's applying noise reduction.
01-15-2024 07:39 PM - edited 01-15-2024 07:40 PM
Why have you opened up a new discussion - "as a reference point" is not very explanatory, what will likely happen is that you get two concurrent broken conversations with folks getting confused between the two. Strongly encourage you to delete this duplicate thread and stick to your original.
01-16-2024 09:02 AM
@Tronhard wrote:Why have you opened up a new discussion - "as a reference point" is not very explanatory, what will likely happen is that you get two concurrent broken conversations with folks getting confused between the two. Strongly encourage you to delete this duplicate thread and stick to your original.
Original is sometimes hard to find after moderator moves it.
01-16-2024 10:54 AM
"ISO 25,600 most likely" Not most likely, it is absolutely the reason.
This is one of the problems of using a lens at f11. Selecting f8 and 1/1600 (which should easily be fast enough SS) would permit the ISO to be lowered to 6,400. One of the 150-600mm super zooms could likely permit an ISO of 3200 or nearly anyway.
If you shoot raw and have Photoshop, have you tried color noise reduction in the Camera Raw filter?
01-16-2024 01:54 PM
I agree with Ernie that given the lighting conditions (and aperture limitations), you need to drop the shutter speed. 1/1600 is fast enough to freeze the subject motion and you would probably be OK at 1/1000 for many captures.
Attached eagles were captured with 1DX II and III bodies with EF 400 f2.8 and EF 800 f5.6 glass using 1/1600 shutter speed. Had lighting conditions required, I wouldn't have hesitated to drop down to 1/1000 or 1/800 as needed.
Rodger
1DX II, EF 400 f2.8 +1.4x, f5.6, 1/1600
1DX III, EF 800 f5.6, f6.3, 1/600
1DX III, EF 800 f5.6, f6.3, 1/1600
01-16-2024 02:45 PM
Yes, I think you hit the nail on the head, my shutter was a bit to high.
Much appreciated.
01-16-2024 02:46 PM
I think that you are right, I will test it again.
much appreciated.
01-16-2024 02:50 PM
I limited the auto ISO to 6400 and will continue to test it up and down.
much thanks
01-16-2024 02:59 PM
Cool, let us know if it helps!
