06-06-2023 09:58 PM
I have a Canon Eos R10 that was working fine and then I put it up for the evening and now it won't power up.
06-07-2023 12:32 AM
Hi and welcome to the forum:
Sorry to learn you are having this issue. In order, I would suggest the following:
1. Make sure the battery is fully charged - you may be wise to get a battery charger for this model if, as I suspect, it does not come with one.
2. See if you can source a known good battery. You might be able to persuade someone who uses the LP-E17 batteries, or a camera store to let you try a charged battery to eliminate that the battery is not the issue, or the charging cable.
3. If it is clear that battery is not the issue, call 1-800-OK-Canon to talk to the tech support people.
06-07-2023 07:08 AM
Did it get wet? Make sure your battery is fully charged. Remove any lenses or mount adapters. Remove the memory card,
Does it power up? If not, contact Canon Support for a possible repair.
