09-09-2021 07:09 AM
Hello, im currently new to Photography and Cameras and stuff. Im currently having problem with my 5months old CANON 80D. I wasnt able to use it for 2 weeks and i just stored it to my Cabinet , (Camera still works fine when i store it)
Until today, when i put my CANON 70-200MM f4 on it . I was in shock that i cant shoot a photo ,or it wont even focus at all.. and i try to change some SS/ISO and it has already an error 1...
as i get the error 1 , i try to swap my lenses to my other camera which is canon also,, the lenses seems working fine with the other camera ,and the 18-50mm lenses that i transfer to my 80D is not focusing again same as my 70-200mm.
I already did clear all the functions and reset the camera settings but still same problem..
I dont know what to do ,since everytime i search in youtube, seems all problem is with the lenses..
and it seems my lenses is fine , i dont know what to do. pls help? i only have like 1k photos taken with my 80D for 5months
09-09-2021 08:56 AM
You are still within warranty, since it happens with 2 lenses, call Canon at 1-800-652-2666.
09-10-2021 10:28 AM
I am just curious but why search youtube and not think to call Canon? Calling Canon should be the first thing you do. They will assist you and probably have some suggestions of things to try before asking for a return for service. It still may be something easy to fix. It is unlikely the 80D broke itself just sitting on a shelf for 2 weeks.
BTW, unless you try your two lenses on a known working camera, you can't say it is not them at fault.
09-10-2021 10:30 AM
"... it has already an error 1... "
If your camera and lens aren't making solid, good, contact on all of the contact pins, your camera will give you this error.
09-12-2021 07:24 PM
