10-29-2022 04:22 PM
Would anyone have advice on if my Canon 6D mirror might be rubbing the rear lens element on my EF mount Rokinon 14mm f.2.8? I used the lens for the first time the other day and noticed some knicks had formed after actuating the shutter. The rear lens element does protrude past the rear of the lens.
10-29-2022 04:36 PM
EF lenses should not protrude into the camera body like EF-S lenses. I would stop using the lens to prevent further damage to the lens or mirror. Also since its a 3rd party lens causing this problem I wouldn't use it.
-Demetrius
40D, 5D Mark IV, EF 16-35mm F/2.8L III USM, EF 24-70mm F/2.8L II USM, EF 28-135mm F/3.5-5.6 IS USM, EF 50 F/1.8 STM
430EX III-RT & 600EX II-RT
10-29-2022 05:21 PM
Is this the lens you are talking about?
10-29-2022 05:44 PM
Thank you for your response. That's close though the item name differs slightly. The item name of the lens I have is as follows: Rokinon 14mm f/2.8 ed as if umc canon ef fit. The description labeled it as a lens that was compatible with full frame DSLR's.
10-29-2022 05:44 PM
10-29-2022 05:58 PM
Is this a Fully manually lens ie manual focus and an aperture ring. I know Rokinon lenses are usually completely manual lenses. They also don't have electronic contacts to communicate with the body.
-Demetrius
10-29-2022 06:01 PM
Yes. It is full manual.
10-29-2022 06:09 PM
Just what I thought there shouldn't be any electrical contacts on the back of the lens to communicate back to the body.
-Demetrius
10-29-2022 06:59 PM
I have both the camera and the lens. The mirror should not collide with the lens, and nothing should be extending out of the lens mount into the camera body.
Can you take a photo of the lens mount where something is coming into contact with the mirror?
10-29-2022 07:14 PM
