10-27-2023 02:26 PM
My husband has a Canon 60D and suddenly has focus problems. Canon batteries are old but recharged. Could a fuzzy focus be the result of old batteries? Any thoughts?
10-27-2023 02:37 PM
There any one of a number of factors that could cause fuzzy photos, up to and including a failed lens or bad settings on the lens or camera.
Try this test. If the lens is an AF lens, aka autofocusing lens, then make sure the lens is set for AF mode. Switch the top dial to the Green [A+] mode, and try to take outdoor photos on a sunny day. Even it it is a little cloudy, try the test anyway. The point is we want natural sunlight, not artificial indoor lighting.
10-27-2023 03:23 PM
Posting a sample of an affected photo with the EXIF info intact would go a long way towards helping sort things out. It seems unlikely to me that it would be a battery issue, but I've been wrong before. Why, just yesterday I . . . Oh never mind.
Does the problem exist with more than one lens? Is there another lens you can test with? Do you have enough lighting and contrast in the scene for the AF to work properly?
And the list of possibilities goes on from there . . .
10-27-2023 08:49 PM
When you say “fuzzy focus” I get the impression you are looking at “fuzzy focus” in the viewfinder, and not “fuzzy photos” on your computer monitor.
If that is the case, my first thought is that the diopter adjustment has been moved and your viewfinder is now fuzzy. Just rotate the little wheel until the viewfinder is clear again.
10-29-2023 11:58 AM
Focus is fuzzy in both viewfinder and on computer screen. Hubby just took two more pics using two different lenses. Same less than stellar results. Camera used mostly for wild bird photos. Just started having "fuzzy focus" problems a few days ago.
10-29-2023 12:01 PM
Any chance he has reset the shutter speed too slow causing camera shake blur (or maybe accidentally turned off IS on IS equipped lenses?
Rodger
