07-29-2019 12:54 PM - edited 07-29-2019 12:57 PM
The shutter for one of my 5D bodies seems to have gone. Interestingly, it still sounds ok, but I get the 'No Image' on the display screen and there's no picture recorded on the card!
I've been told today by a camera technician that Canon no longer supplies 5D Mkii shutters, as this has been phased out, is this correct? I'm concerned long term as have several Mkii bodies I use for multiple camera time-lapse work, so they clock up a high shutter count. Sure, I appreciate we can purchase through Ebay and mail order, but it would be good to know if Canon still supply ...
07-29-2019 04:08 PM
"I've been told today by a camera technician ..."
Obvious question why didn't you ask Canon? I suspect the Mk II is out of service life, however.
07-29-2019 04:54 PM
Canon South Africa told our technician it was no longer supported, so thought I would double-check.
07-30-2019 11:20 AM
@TrevorDK wrote:The shutter for one of my 5D bodies seems to have gone. Interestingly, it still sounds ok, but I get the 'No Image' on the display screen and there's no picture recorded on the card!
Has a qualified Canon technician actually diagnosed your camera? The symptoms you describe aren't exactly those usually reported when the problem is a broken shutter.
08-05-2019 01:44 PM - edited 08-05-2019 01:46 PM
Just following up on this, yes correct Bob... the camera technician fitted another shutter and same issue, so gather it must be the circuit board that's failed. Given the cost of a replacement board and fitting being about $500, it's sadly the end of the road for this camera, having just bought it from a dealer seven months ago, so it was just a month after the six-month shop warrantee! It only had 31k actuations compared to my other 5dMk2 body that has 200k and is still going strong, not that it's shutter related.
