10-23-2020 08:02 AM - edited 10-23-2020 08:03 AM
Dear Experts:
I got a like new (3000 Actuations) 5D MK ii last year. Last saturday it started acting wierd in Standard Picture style mode. I decided to reinstall the firmware to see if that would help. Yesterday I reinstalled the Canon firmware and my Camera is dead. Only the top electronic panel is live. The Live view / Menu is in accessible.
I tried all the tricks:
1. Remove Battery
2. Removive lens
3. Remove and replace CF card
4. Remove time and date battery.
PLease help! I cannot buy a new Camera and I have some lenses I cant sell for half a price.
NOTE: I DID NOT INSTALL MAGIC LANTERN.
10-23-2020 11:01 AM
10-23-2020 11:02 AM
So sorry but do give Midwest a call.
10-23-2020 11:24 AM
Agree with Ernie that Midwest is your best bet at this point.
The issues you were seeing may well have been related to a main logic board failure and during the firmware update process the operating firmware became completely corrupted during the update process due to the hard fault with the board. This is an expected outcome if there was already an issue with the board.
The silver lining in this cloud, if there is one, is you didn't really damage your camera by trying to update the firmware but just made the existing fault very apparent. It would ultimately have created more problems with your camera reducing it to completely unworkable so it is probably good that it appeared now rather than during a critical shoot.
I have never used Magic Lantern and know nothing about it but is it immediately evident to the user when it is installed? Is it possible Magic Lantern was installed before you got the camera since it was used? If so, is there a special procedure when installing firmware in a camera that has been modified with that firmware?
Rodger
10-23-2020 11:47 AM
No. This Camera never had ML installed in it. The issues is I need access to MENU options to install another software such as ML. I dont even get the "Red light" blinks when I turn on the Camera
10-23-2020 12:15 PM - edited 10-23-2020 12:16 PM
Something doesn't add up here. In my experience it is not possible to install the same firmware version on top of the same existing firmware. The camera will not let you even try.
10-23-2020 12:38 PM
I cannot find Midwest Camera online. I see a midwest photo in 2887 Silver Dr. Columbus, Ohio.
10-23-2020 12:51 PM - edited 10-23-2020 01:48 PM
Midwestcamera-dot-com
10-23-2020 11:20 AM
You actually might try magic lantern, it can't hurt. If it does give you control back, you can just not use it.
10-23-2020 10:58 AM
"They only address known camera design "bugs" ..."
And feature enhancements or additions. All is well documented so you need to read it to see if what the new FW has that you need. Otherwise it is not necessary.
10-23-2020 01:34 PM
