02-19-2018 03:27 PM
Hello. I'm new to the forum but no to Canon.
I picked up an old 1DIIN just to tinker with. It was sold cheap because of what looks like a senor issue. When pictures are taken wide open the white area in the picture occurs. When a lens is stopped way down it almost goes away and in some cases is gone completely.
Sensor problems most likely. Anyone seen this before and what is the solution?
02-19-2018 03:33 PM
Broken shutter.
02-19-2018 03:42 PM
how costly is that to fix?
02-19-2018 04:08 PM
Probably too old for Canon to still support, one of the aftermarket shops might do the repair. But it will be more than the body is worth.
Fairly rapid obsolescence due to lack of parts/support is very common now. It basically undoes the green/environmental good done through other measures like electricity conservation.
You can buy a used working 1D2N body from B&H with a 90 day guarantee for $500.
If you are into do it yourself you could buy one of the Chinese shutter assemblies on ebay in the $60 range and attempt to repair it yourself. If the shutter went out on my old 1D2 AND I had access to a genuine Canon replacement I would probalby undertake the repair but I wouldn't go to that level of trouble to put in a likely counterfeit part that may not work at all and if it did it would likely have a short and imperfect life.
Rodger
02-20-2018 02:07 PM
Call Midwest Camera Repair. No biggie as shutters are not difficult to replace. Estimate $350 give or take.
02-20-2018 02:09 PM - edited 02-27-2018 01:26 PM
The EOS 1D Mk IIn is a great camera. Of all the older 1 series I had, I kept my Mk IIn. I still use it quite a bit.
02-20-2018 02:16 PM
"The EOS 1D Mk IIn is a great camera. Of all the older 1 series I had, I kept mu Mk IIn. I still use it quite a bit."
Agree and it nicely illustrates you don't need a huge number of megapixels to provide very nice images. I plan to hang onto my 1D Mk II for my daughter and it has a pretty low shutter count so hopefully it has several years left in it.
The low light/high ISO performance of the 1DX Mark II is nice but that same full frame sensor with 12-14 megapixels would have offered noticeably lower noise using its current generation of sensor technology. I am not convinced that merging the studio and sports lines into a "unibody" was the best decision. It is a nice camera body but we always want more and in my case lower noise is preferable to more pixels.
Rodger
02-27-2018 12:54 PM
I got a couple of bids for fixing it but decided to sell it to a local guy who wanted to give it a shot for fixing.
02-27-2018 05:01 PM
@wq9nscwrote:"The EOS 1D Mk IIn is a great camera. Of all the older 1 series I had, I kept mu Mk IIn. I still use it quite a bit."
Rodger
What you say may have been true when the 1D2N was current. But we're now firmly mired in the Era of Huge Prints, and 12-14 megapixels are unlikelly to do the job at the magnifications one currently sees.
02-28-2018 05:36 PM
"But we're now firmly mired in the Era of Huge Prints ..."
Yeah, I know. What a pity back in the day we had to be content with 2x3's because we couldn't make a big print. I think I'll throw my 1d2n in the lake.
