Cannot import images to my macbook air from EOS T6i
MValentin
Though I have downloaded many images to the same macbook air, fromt the same Canon EOS T6i, I can no longer get the camera to be seen by the computer.  No images will import.  I, of course, do not have the canon software on my mac, because there is no disk slot.  The Canon web site says that I do not need software with OS El Capitan. Canon does not offer web downloads of basic camera software.  I have tried everything that I know to try.  Any ideas?
3 ACCEPTED SOLUTIONS
You don't need the Canon software, but if you want it you can download from the link I sent you.
If you connect camera and open Image Capture you will get the following:Menubar_and_Image_Capture_and_Re__Cannot_import_images_to_my_macbook_air_from_EO____-_Canon_Community_and_Inbox__23_messages__19_unread_.jpg
Select the  circled dropdown and choose the action you wish.
Advice about cable is good. Use the USB cable that came with the camera.
R6 Mark II, M200, Many lenses, Pixma PRO-100, Pixma TR8620a, Lr Classic
There doesn't appear that the cord is damaged, but that makes the most sense.  And yes, mine is a T6s also.
I'll give it a try.
Thank you.
Wifi is turned off on the camera?
13 REPLIES 13
jrhoffman75
You can download and install all the software. Go here and download the EOS Soultion Disk file. Its everything on the CD for computers that don't have a CD.
https://www.usa.canon.com/internet/portal/us/home/support/details/cameras/dslr/eos-rebel-t6i-ef-s-18...
But, thats not your problem, since you were able to download at one time.
I have a MacBook Air, so I will try and assist. What happens when you insert the SD card (or connect the camera)?
Hello John,
When I go to download the eos solution file, I click on my camera and it says that it has detected an OS that doesn't require software.
When I plug the camera in, nothing happens. The computer doesn't seem to see the camera.
kvbarkley
VIP
VIP
Run ImageCapture with the camera plugged in. Do you see anything?
It says that I have no camera or scanner selected.
Try a new cable. My T6S works just fine in several computers.
I'll give it a try.
Thank you.
Not if his camera does not show up. 8^)
Some USB cables are charging only and don't have a data connection. Offical Canon cable is a data cable.
Not to be insulting here, but this happened in another instance - camera won't show up unless cable is plugged in and it is switched on.
Holiday
