05-01-2016 10:47 PM
Though I have downloaded many images to the same macbook air, fromt the same Canon EOS T6i, I can no longer get the camera to be seen by the computer. No images will import. I, of course, do not have the canon software on my mac, because there is no disk slot. The Canon web site says that I do not need software with OS El Capitan. Canon does not offer web downloads of basic camera software. I have tried everything that I know to try. Any ideas?
05-02-2016 09:53 AM - edited 05-02-2016 09:55 AM
You don't need the Canon software, but if you want it you can download from the link I sent you.
If you connect camera and open Image Capture you will get the following:
Select the circled dropdown and choose the action you wish.
Advice about cable is good. Use the USB cable that came with the camera.
05-02-2016 09:54 AM
There doesn't appear that the cord is damaged, but that makes the most sense. And yes, mine is a T6s also.
I'll give it a try.
Thank you.
05-29-2017 07:36 PM
05-02-2016 06:38 AM
You can download and install all the software. Go here and download the EOS Soultion Disk file. Its everything on the CD for computers that don't have a CD.
But, thats not your problem, since you were able to download at one time.
I have a MacBook Air, so I will try and assist. What happens when you insert the SD card (or connect the camera)?
05-02-2016 09:28 AM
05-02-2016 09:57 AM
Not if his camera does not show up. 8^)
05-29-2017 07:22 PM - edited 05-29-2017 07:36 PM
Hi, I have a Macbook Air, with Yosemite. I just got my Rebel T6 yesterday and was able to upload pictures just fine. Today, the computer is not recognising the camera, I went to Applications ---> USB ---> and it is not listed.
As you can see from the screenshot I have the software downloaded and on my doc, it just doesn't find the camera when connected through USB, and yes, I am making sure I turn the camera on after it is plugged in to the Mac. It also doesn't show up in Applications ---> Image Capture. Nothing does.
I should also add it is a Canon USB, I just bought it brand new with all of the extras included. Please Help!
05-29-2017 07:36 PM
Wifi is turned off on the camera?
05-29-2017 09:55 PM
That was it! Thanks so much, I set a Wifi nickname yesterday and guess I left in enabled
05-30-2017 08:16 AM
Glad I could help, and also that it was a simple fix.
05-02-2016 09:38 AM
Run ImageCapture with the camera plugged in. Do you see anything?
