08-19-2024 10:18 AM - last edited on 08-20-2024 09:59 AM by Danny
Here's the info: Canon T7, San Disk Ultra 32GB (not locked), Lenovo laptop with Windows 11, Firefox browser. Hope that is enough. I have had this problem for about a week. The photos show up on the screen on the camera. I insert the card into the slot on the laptop. I get the "ding" and the screen pops up. After that, nothing but a blank screen for photos. I did this yesterday and let it "sit" for at least a half hour to see if it resurrected. Nothing. Never had this trouble before. Have downloaded loads of photos with this card. Any and all suggestions are welcome.
08-19-2024 10:51 AM
Try using a USB cord to get the images to the computer, and then reformat the card in the camera to continue using the reader.
08-19-2024 01:56 PM
Have you tried direct download with a standard USB cable? The driver for your card reader could have gotten corrupted, or worst case, it could have just died altogether.
You might double-check to see if there are any Windows Updates that might help. Barring that, the next thing (and what I would do) is to get a small card reader. This one is very much like the one I have - it has both common USB ports, and micro & standard SD card slots & it's about $20 on Amazon:
08-19-2024 03:06 PM
What "screen" pops up when you insert the card in the computer? Are you using EOS Utility?
The card should appear in Windows File Manager as a drive. Does it? If not, your internal card reader is suspect. Try reading other SD cards. If it DOES appear as a drive, open it, open the DCIM folder. Your photo files are there. Move them to the computer.
You DO NOT need EOS Utility to get photos from the memory card to the camera. It just complicates things, in my view. Just use a USB cable to connect camera to computer, or use an external or computer's internal card reader.
08-19-2024 03:51 PM
What type of SD card are you using?
Is it full-size ir micro-SD with adapter?
What brand and where did you get this card from?
Thaese details could be significant
08-27-2024 09:44 AM
Got two emails regarding this question. Card: SanDisk Ultra 48 MB/s 32GB. USB cable: will try it but I feel the more between the source and destination, the more interference. I have a card reader....somewhere.
I can see the photos on the camera but only get the opening screen when I insert the card but nothing after that. It just sits.
Tried card reader and got even less...not even the blank screen. Title isn't accurate as I insert the memory card directly into the slot on the laptop. Tried USB cable but manual didn't have anything on it. Attached cable to camera, turned on camera, inserted into USB slot in laptop. Nothing. Will take the card and laptop to Staples as I have a maintenance contract. Will call first to see if this is covered. If not...a trip to my son and grandson.
08-27-2024 09:53 AM - edited 08-27-2024 09:56 AM
John,
I don't know that it will make a difference. but I'd suggest that you attach the cables first, and then turn your camera on. Any peripherals: cables, lenses, cards, batteries, etc. should be attached while the camera is off.
Steve Thomas
08-27-2024 10:29 AM
Did that. Taking the laptop and card to Staples to run a virus scan. Tech said he couldn't guarantee a solution but a scan might uncover a problem. Frustrating, to say the least. Technology is great until it doesn't work.
08-27-2024 09:58 AM
Tried everything but sacrificing an unblemished lamb. Card: SanDisk Ultra 48MB/s 32GB; have used this card many times. Inserted memory card (not locked) into slot on laptop. I only get a sound and blank screen but nothing happens. Cable: nothing; inserted cable into camera port, turned on camera and cable into USB slot on laptop. Found the card reader; nothing. Tried another card; PNY Technologies 2.0GB; photos visible on camera but after inserting the card, I don't even get the blank screen when inserted. If my son and grandson can't help, it's off to Staples to see if the service contract covers this. The other two cards have been used and downloaded perfectly.
08-27-2024 11:42 AM
I have had a couple of card readers die since I first started using them back in 2005 so I wouldn't be surprised if it is a card reader issue.
Good luck getting it resolved, it will probably take a little money but no animal sacrifice 🙂
In general, I do NOT like cards in and out of cameras. An SD card interface is likely the most mechanically robust of the ilk but all of them can suffer from repetitive use. I use the ethernet connector on my 1 series bodies for transfer and the USB port on my other cameras for transfer with the card remaining happily in its secure little home.
Rodger
