10-19-2023 02:54 PM - last edited on 10-19-2023 03:38 PM by Kristoff
I have the Canon EOS 800D, European verson of the EOS Rebel T7i. I was trying to shoot the recent eclipse in Manual mode.
I had the camera set at ISO 1000 and shutter speed 1/4000. That was still too bright to capture the eclipse. So I tried to set the Exposure Compensation to -7 but I couldn't change it, it was stuck on AEB, Auto Exposure Bracketing, and even when I tried using the widest range, which only went 2 1/3rd stops + and -, it didn't make three exposures and the one resulting exposure was too bright. I spent almost the entire eclipse trying to turn off the AEB, including in the menu, but could never get it turned off.
It seems ridiculous that in manual mode this can't be turned off! Does anyone know how it might be done?
10-19-2023 03:35 PM - edited 10-19-2023 03:38 PM
hartgh,
Try pressing the "Menu" button and navigating to the screen where you see"Clear Settings", press the "Set" button and go to "Clear All Camera Settings" and pres "OK".
That should clear any settings you've changed and put the camera back in "neutral".
10-19-2023 05:35 PM - edited 10-19-2023 05:37 PM
I'm not sure if you did this, but this is the way it works on our T7i . AEB should disable when you turn off the Camera. To disable during shooting, you have to either go into the Expo.comp/AEB menu (Shoot 2), press "Set" and adjust your AEB spread to "0" by turning the main dial (just behind the shutter button) counter clockwise as you are looking at the back of the camera. When it gets to 0, AEB is disabled. You can also do this by pressing the "Q" button and tapping the Exposure compensation scale, then turning main dial.
As far as I know, it will not automatically snap off the three shots unless you use the timer or use continuous shooting and hold the shutter down. It will stop after the three exposures are taken in continuous. I suspect that is why you just got one bright shot.
Newton
10-19-2023 06:00 PM
Ah! I think you are on to something.
Perhaps the OP didn't take the 2nd & 3rd shots of the bracket sequence? Maybe take 2 more photos?
10-19-2023 06:35 PM - edited 10-19-2023 06:37 PM
@zakslm wrote:Ah! I think you are on to something.
Correct. But it's best done from a tripod with a remote shutter release. I've always used the timer, which will fire off the three shots 🙂
Newton
10-19-2023 06:15 PM - edited 10-19-2023 06:16 PM
I certainly hope you did not take an image of the eclipse with no filter. That is a good way to damage your camera or lens. You can burn a hole through the shutter!
https://www.lensrentals.com/blog/2017/09/rental-camera-gear-destroyed-by-the-solar-eclipse-of-2017/
In any case, you would want a *low* ISO, not a high one to make the camera less sensitive.
10-19-2023 07:33 PM
My typo mistake. It was set at ISO 100.
