01-13-2019 11:36 PM
Hello. I just purchased the Canon 80D and just dummied up a way to extend my battery power to prevent from having to swap out so many batteries throughout filming. I was wondering if there was a same method with dummying up a way to connect the Canon 80D to a larger external storage device so it's not entirely dependent on an SD card?
Thank you in advance for any and all your help Canon community.
01-14-2019 01:55 AM
How larger storage do you want ? you can use 128GB SD card without any issue.
01-14-2019 02:48 AM
Hello. I have a 128 SD, but I was wanting to see if I could extend that to an external drive in the TB range? I was researching and saw that the Blackmagic had this capability; where you could connect a small 2TB hard drive to it. I was wondering if the Canon 80D had this same capability? Or, if there is some way of being able to dummy this to make it happen?
01-14-2019 04:11 AM
You can try it.
01-14-2019 05:26 AM
I know I can try it. I'm asking "how" if a way exists.
01-14-2019 11:23 AM
01-14-2019 12:58 PM
01-21-2019 05:46 PM
Gotcha. Ok, thank you.
