05-23-2015 12:10 PM
The post below prompts a question I have had for a while. I use a 60D and Canon 100-400 mm zoom to photograph birds, and get some really good results. While editing, I notice where the camera has focused, and the results (photo sharpness) appear to wander a little at times. Usually I am shooting at 400 mm, where this lens has a maximum aperture of f/5.6. I wonder if a faster lens, say one at f/4.0, would give better AF results due to its shallower DOF.
I'd appreciate other thoughts on this.
Thanks!
Edward
05-23-2015 02:09 PM
Edward,
A couple thoughts. I use just the center point for shooting birds Turn all the other off. It is common practice to put that point on the bird's eye.
As the aperture gets smaller (larger number) some cameras will slow down theie auto focus speed. I imagine this also effects the AF accuracy. But it will not jump around if you use just the center point.
This photo below was shot with a 500mm lens that is even slower than your 100-400 is. But it is center point only.
It was hand held, too. Av set the lens to f8 fixed. SS was 1/2000 and ISO is 800.
05-23-2015 03:37 PM
05-23-2015 08:19 PM
It might. I don't know if I have seen tests where a, say a f1.2 opposed to a f4 for instance. The actuall cut off for most cameras is f5.6. So I am not sure how much a faster larger ap will speed it up. it sounds like ti should though. Doesn't it?
I have had many, many lenses over the years. Some are just slower to focus and they have the same f number. Other factors figure in for sure.
05-23-2015 08:28 PM
05-24-2015 10:39 AM
"I WAS looking fir another reason to get a 400 mm or 500 mm f/4 though. "
Oh, well, ah, yes, faster lenses focus light-years faster than slower lenses! Go buy iy, today.
But in actual use a couple things need to be qualified. Nothing electronic hits a brick wall where it works and bam, it doesn't.
Almost always it is a curve. So, I suspect as you do get closer to a better light transmission and contrast, the AF is going to lock quicker and be more accurate. Of course the oppisite would be true, also, as conditions worsen.
Even the fact you change your camera from horizontal to vertical can affect the AF speed and its accuracy.
Another problem with this is, lenses are different. Even the same make and model form the same company. The better, higher cost, lenses get better stuff, too. Why would they not? You expect better as you move to "L" level lenses!
However, if you are in good light, I don't think you are going to notice a f2.8 lens vs a f4 being much different. If it is a f4 vs a f5.6, there might be a slight difference. You are getting to that "curve" limiting thingy. Conversely, I doubt you would notice a big difference between a f1.4 vs a f2.8 lens.
As I said, I have had many, many lenses and access to dozens more at work and I don't ever recall the aperture being the reason a lens AF was slower. (Keeping you are not doing a f2 vs f8 of course.) There are just way too many other factors to calculate. I can give you another example. I have the EF 50mm f1.2L II and it is the slowest AF lens I have used in a very long time. So there you are?
05-24-2015 11:41 AM
BTW, here is a recent, favorite image of a violet-green swallow here in the area (Cupertino, CA). The camera and lens did a pretty good job here, one I am happy with.
05-24-2015 11:48 AM
The salient point about that last observation is that an f/1.2 lens, because of its minimal depth of field, requires more accurate autofocus than other lenses do. There's undoubtedly a tradeoff between accuracy and speed; and if you're using, say, an f/4 lens, you might consider speed as important as accuracy. But if you don't get accurate focus at f/1.2, what's the point of taking the picture?
Of course the camera/lens collaboration knows what aperture is going to be used to take the picture. So if you wanted to drive up the cost of an f/1.2 lens, and possibly of the body that uses it, you might incorporate a feature that allows a compromise on accuracy vs speed if the picture is going to use a narrow aperture.
05-24-2015 12:12 PM
"The salient point about that last observation is that an f/1.2 lens, because of its minimal depth of field, requires more accurate autofocus than other lenses do."
So right, Bob from Boston,
In this case the very wide ap of f1.2 did not help.
And it is a very expensive lens. BTW, its big brother, the EF 85mm f1.2 L, is equally slow to AF even with its f1.2 max ap.
I will still go with the lens itself makes more difference that the larger ap does. As well as the camera it is bolted on.
05-23-2015 10:06 PM
