03-21-2021 01:36 AM
I buy the brand now Canon EOs 90d and Canon EF 100mm f2.8L Macro IS USM Lens.
I use Canon EOS Utility 3.12.10.7 Remote live view Shoot to take the picture,
when I use Focus and click On button for focus, after focus with the beep sound,
I click the < or > button 10 times to adjust the focus point, then after few second
or click the shutter button on Utility, it will auto auto-focus again and lose my focus
adjustment.
And the AF microadjustment is not working.
After I add the Canon EF 100mm lens serial number and adjust to +19 or -19, then
take the picture the picture is the same and never changes the focus point!
Thank you.
03-25-2021 12:33 PM
Ok, 100% working now after change the EOS Utility 3 switch icon to "MF". Thank you
03-22-2021 12:18 AM
I only use the camera everyday for 200 pcs size 1/4 to 2/4 inch macro minerals.
I have Canon EOS 77D with EOS Utility and use everyday for over 3 years for macro minerals with no problem. After upgrading to 90D started to have that problem.
03-22-2021 09:32 AM
It appears that the 90D interacts with EOS Utility differently. I suggest you call Canon.
03-23-2021 10:53 PM
I contact support but nothing help.
Canon support:
Thank you for contacting Canon regarding your EOS 90D. My name is Nick, and I'll be glad to address your focus inquiry when using the remote shooting feature of EOS Utility. I suggest that you check to make sure that the switch on the software interface by the shutter button is set to MF, not AF. It might also help to clean the metal contacts between lens and camera with a lint-free lens cloth.
03-25-2021 12:33 PM
03-22-2021 06:31 PM
Have you updated EOSU from the 90D support site?
03-23-2021 10:54 PM
I have the last firmware 1.1.1.
03-23-2021 10:58 PM
I suggest that you try enabling BBF, Back Button Focus.
03-25-2021 12:03 AM
Is same, After I changed Back Button Focus to Metering Start.
03-25-2021 06:15 AM
@Waiman wrote:Is same, After I changed Back Button Focus to Metering Start.
Your "change" sounds like it is actually the default behavior. The change you need to make is to remove [AF START] from the Main Shutter Button. Remote control software only activates the Shutter Button.
The Custom Controls menu has its' own reset. Reset the Custom Controls, and then change just the Shutter Button so that its' only function is [METERING START]. This means removing [AF-ON] from the shutter. I probably have the function names wrong.
