Beep in 1DX mkii
Malco
Not a big problem, but the beep doesn't work in my 1DX Mk ii
I have the beep enabled and drive is set to one shot.
I just got the camera and I updated to the latest firmware.
Mal
5 REPLIES 5
diverhank
You might want to make sure the option is set for each of the modes you will use...they are independently remembered for each mode (e.g. Av would have a different set than Tv, or M, etc.).
Diverhank's photos on Flickr
I checked it out the beep is set to on. The camera focuses properly , the green light comes on and the AF in the lower right cornor is on, but no beep.
I just got my 1DXM2 also and it came with firmware V 1.13 which I haven't upgraded to 1.14 yet.  I checked and the beep does work on mine but I turned it back off because I don't like the camera beeping at me.
Maybe someone else who has upgraded the firmware to 1.14 can comment whether this is a glitch with that version. I downloaded the 1.14 update to my PCand will probabably install it after shooting a soccer game tomorrow night however if it has "glitches" then I will hold off until 1.15.  My only issue with the camera is connect time is a little slow using the gigabit LAN connector but that may not be just the camera issue; it takes up to about 45 seconds to connect after the LAN connection is enabled but then file transfer is very fast.
I upgraded my firmware to 1.14 and the beep still works fine.  I turned it off for a while, then turned it back on, and it is working as designed.  For me, when "little" things like that seem to be a problem on a $5400 purchase, I tend to want to get it looked at immediately as I worry about other things that may be wrong as well.  I'd have Canon look at it.
I e-mailed Canon I will wait and see what they say.
