02-07-2024
04:41 AM
08:16 AM
1) If I want accurate colour representation and I am using artificial lighting, does it have to be 5600K?
2) What's the difference between strobe lights or a COB (Chip on Board) LED light when it comes to taking photographs? Is one superior over the other?
02-07-2024 07:38 AM
In terms of accurate color, you'll want all the contributing light in your scene to all be at the same color temperature. If not, and using mixed color temperatures, that can lead to very poor results. And even if shooting in RAW, it may not be possible to fully correct.
By "contributing" light, I mean both the ambient and any extra lights added to the scene.
Lights such as COB LED are continuous lights. Are continuous lights though superior? Or are strobes superior? The answer is neither and both. i.e. it's going to depend upon what you're doing in terms if one will be better vs the other.
For what I do, I need strobes/flashes due to the following main reasons:
Other aspects of lighting to look at:
Back to color temperature. It will ultimateliy depend on if the continous lights are fixed or variable. Or, if you want accurate color reproduction or need creative freedom. I did an experiment a while ago to see what color temperature would be best when using my Profoto strobes with my current camera. I found it to be 6000º K. (see the linked article for details).
Finally, when accurate colors are crucial, do use a color chart and a proper color workflow. Ensure you're working in the largest color space possible and that your display is calibrated. If doing prints, ensure you are using the correct profiles for the media you'd be printing to.
02-07-2024 06:18 PM
Ricky, Thanks for jumping in 🙂
02-07-2024 05:26 AM - edited 02-07-2024 05:29 AM
in regards to your first question, The color temperature (Kelvin) you select depends on your preference. 5600k is the industry standard for outdoor natural light. Going lower will increase the intensity of reds and yellows. Going higher will increase the intensity of blue or cooler shades. 5600k is a safe starting point that allows you to go in either direction.
Your second question is not as straightforward to answer because it depends on the type of photography and conditions you are shooting under. Freezing moving subjects, maximizing lighting with minimal shadows. Shooting indoors vs outdoors and power availability. Since I am not a lighting expert, I hope someone with more experience will chime in on this.
02-07-2024 07:38 AM
02-07-2024 05:49 PM
Many thanks Ricky. Can you recommend any good resources for learning how to use a color chart and a proper color workflow?
02-07-2024 06:18 PM
02-07-2024 06:20 PM - edited 02-07-2024 06:22 PM
There are a ton on YouTube. I personally use Datacolor products and Adobe Lightroom. Search YouTube for “Datacolor spyder lightroom”. Note that “spyder” isn’t a typo; it’s their product name. Lots of really good presentations to include one from Canon Explorer of Light, Sal Cincotta.
Another popular brand for color charts is X-Rite. There would be similar resources on that product.
02-07-2024 06:39 PM
Excellent advice from Ricky!
I mostly use studio strobes but I have some LED continuous lights (primarily for video). Be careful of the "value priced" offerings in both strobe and continuous because some will suffer significant colors shifts with both age and temperature. So you may start with lights of near perfectly matched color temperature only to have them drift in different directions over a session. The better quality light sources are far less prone to this annoyance.
And Ricky is spot on with the problems of dealing with mixed color temperature. I frequently shoot sports and one high school field I shot it had a mixture of mercury vapor and high pressure sodium discharge lighting which have very different color temperatures. It was a nightmare to get acceptable results from that field, trying for perfection would be pure folly.
Strobes are perfect for high output and for freezing motion which is why they are my primary artificial light source. Setting up continuous lighting is typically a little easier since you can easily see the pattern of lights and shadows cast by your lighting but the high power modeling lights in my Hensel strobes provide a good starting indication of how the lighting will appear when the strobes are fired.
Rodger
