7D using tripod arm problem
Glynn
When I used my tripod arm with my 7d to take a downward photo of an old photo on a table the photo took well and filled my screen when it showed in the view finder window. However, when I reviewed it, the photo showed sideways, the opposite way in which I took the photo. When I took out my card to put on the computer all the photos were now verticals instead of horizontals. I can turn them in editing but i just need them to stay horizontal photos. Is there a setting on the camera that will keep them from changing from horizontal photos to vertical photos?
wq9nsc
Go into your menu setting under the wrench symbol, select auto rotate and turn auto rotate to off.
Rodger
2 REPLIES 2
wq9nsc
Rodger
Thank you. This solved my problem.
