08-29-2018 02:21 PM
A friend recently gave me a 7D in excellent condition after he upgraded. When I try to connect to the computer it does not recognize the camera. The EOS Utility program show the connect window, but nothing happens. Any help is appreciated.
08-29-2018 03:15 PM
08-29-2018 03:27 PM
I just tried connecting another Canon camera using the same cord and USB port. It connected immediately.
08-29-2018 03:28 PM
Is there anything in the camera settings that would affect outgoing data?
08-29-2018 03:56 PM - edited 08-29-2018 03:57 PM
Not on these later cameras. The Canon guidance says to set Auto Power Off timer to "OFF", but that shouldn't affect inital recognition.
Give Canon a call at 1-800-OK-CANON.
08-29-2018 04:26 PM - edited 08-29-2018 04:30 PM
A question if I may?
Why are you connecting the camera to your computer to begin with? I can think of two reasons:
1. You want to tether the camera to the computer so you can see, via the computer screen, what the camera sees when you shoot. This is a comparitively rarely used feature, so I am leaning towards #2..
2. You want to transfer files to the computer. In that case you would be better off to take the card out of the camera and use a card reader (I gather your camera is the 7D not 7DII so it has a CF Card). That way you will get the file transfer at a faster rate and you won't be chewing through your camera battery to transfer the files. You can pick up a decent card reader for not a great investment, especially worth it if you got the camera for free (or did I mis-interpret your original post?).
08-29-2018 04:32 PM
I have a card reader now. If there is nothing I need to connect for (firmware or such) then I quess it is not an issue. I appreciate the quick responses and answers.
08-29-2018 04:38 PM
Glad to help if I can.
Firmware updates are designed to be downloaded to your CF card so you would install them via the card reader onto the card, which is then used to install the updates.
08-29-2018 04:51 PM
Don't worry about firmware updates. Canon will not usually update firmware of discontinued models.
However, you may still need to connect your 7D to your PC for Canon Utilities, updating/adding picture styles and changing copy rights info etc.
Please also read the content here :
08-29-2018 04:56 PM
I have a 7D and must say that the firmware updates always been delivered by the card, the instructions encourage you to do so as I recall. I have been able to access and change the copyright info direct from the camera menu.
08-29-2018 06:56 PM
@Tronhard wrote:A question if I may?
3. Possibly the OP wants to synchronize the camera's time with the computer's or update some of the user-supplied information (author's name, copyright notice, etc.).
I would remind the OP, who didn't say what version he was using, that a 7D wants Version 3 of EOSU.
