12-24-2016 09:03 PM
I am using a T5 with EFS lenses and I just purchased a new 85mm 1.8 EF lens. It takes great photos but when I transfer them to my PC, the PC doenst recognize them and shows them as "grayed-out". I can view the images on the camera after they are taken but the PC is not recognizing them for some reason. Any ideas?
12-24-2016 09:42 PM
Hi!
To have a better understanding of your issue, please let everyone know what operating system (Windows Vista/7/8 or Mac OS 10.X) you are using.
Thanks!
12-24-2016 09:44 PM
Windows 7 HP computer. It has always transferred fine with no issues but once I used the EF lens, it would transfer photos but they cant be viewed on the PC.
12-24-2016 10:47 PM
You may have set the camera to shoot in RAW. See if you can get the file properties & if they end in CR2 they are the RAW files & you need to install DPP from your CD that came with the camera.
12-25-2016 09:43 AM
"... I just purchased a new 85mm 1.8 EF lens."
Whatever the problem is, it is not because you used the new lens. I also doubt it is because you may have switched to RAW.
However, what software are you using to view the photos? You did install all the Canon provided software, I guess?
12-25-2016 10:44 AM
The lens is just a lens.. it has nothing to do with how the camera digitally records your images (that's up to the camera).
If you can look through the viewfinder and see through the lens, then you're seeing what the camera would see. The lens has an auto-focus motor and aperture blades (to control how much light can flow through) but that's it.
But the notion that you *can* view the images on the camera itself indicates that the camera and lens are working fine. This is likely just an issue with image format.
The camera has the ability to record images as "JPEG" or "RAW". JPEG is easy and excellent for "final" image format (meaning if you don't need to adjust the images). But RAW is better if you want to be able to adjust the image. The camera also has a RAW+JPEG mode (each time you take one shot, two image files get recorded... one RAW and one JPEG).
My guess (as has already been suggested by cicopo) is that the camera is recording in RAW and you aren't using any software that knows how to read the RAW files from your camera.
Whether a RAW file can be viewed on your computer is entirely dependent on *which* photo software you are using. Canon's own software will, of course, recognize the images. But other software (Microsoft's software, Adobe software, etc. etc.) would depend on if that particular software has a RAW codec for your camera.
From Microsoft, I *think* this is the latest download for Windows 7: https://www.microsoft.com/en-us/download/details.aspx?id=26829
However that would only help if the software you are using is Microsoft's software. Adobe's software is extremely popular and you have to get Adobe's Camera RAW codec's from Adobe.
12-25-2016 11:34 AM
"It takes great photos but when I transfer them to my PC, ..."
This tells me at some point before the addition of the ef 85mm f1.8, you were viewing your photos on your computer? If this is so and you changed nothing, it is not the file format. The thought of it being an accidental change of format (to RAW) is a long shot at any rate as most available software for a T5 will show jpg or RAW files. If you are using the Canon provided software it (RAW format) isn't even a consideration.
12-25-2016 01:59 PM - edited 12-25-2016 01:59 PM
@ebiggs1 wrote:"It takes great photos but when I transfer them to my PC, ..."
Maybe not; but if you aren't, it probably is. Windows 7 is less reliable than Windows 8 or 10 at recognizing the embedded JPEG in a RAW file. If the OS doesn't have the Canon RAW Codec installed (and maybe even if it does), you may have to manually specify the program (e.g., LR or DPP Viewer) to be used to read .CR2 files.
12-25-2016 04:48 PM
Robert, Merry Christmas, from Boston,
Until this is confirmed or not, "...you were viewing your photos on your computer?", it is a moot point. It sounds like all was well until the 85mil came along.
12-25-2016 07:28 PM
The images appear on the Windows 7 PC as JPEG but each one is "grayed out" and the photo is not visible. The format of the camera was not changed. Even some of the photos that were on the camera before the 85mm lens are being transferred and appearing "grayed out" and I know these photos were taken with a different lens.
I am starting to think the SD card may be the issue.
